180 rear wheels
Hey guy got a 180 with power adjust rear wheels that are junk! Trying to figure the best idea at the moment. New power adjust wheels and 28 inch tires will set me back almost 3000! 30 inch wheels and rubber would be about 600 less but is there a center that would work? Got some 30 inch rims with 8 on 8 centers that I think will work but they are a little to narrow. Thought I read somewhere that 30 inch could be put on the rear??
28 inch power shift wheels were standard equipment. 30 inch power shift wheels were an OPTION on later 180's. They had 5 rails instead of 4 rails. They require a different wheel center too.
It probably not the look you want but would wheels off a Gleaner E combine( wide 24 Tires) fit that tractor. I have a parts machine sitting for years that wheels could be had for a reasonable offer. I thought I would put them on a WD but can't go for that look or size would probably make it go to fast&less power. Bought extra Spin Out Rims and fix them up as needed? The way it going those wheels & tires will be around after I am gone but they are handy when ever the carcass has to be moved?? Cleddy
