1810d 4wd ?
I pulled my drop box off and have stripped gears again. Also while looking up into the transmission from the drop box hole the gear the stationary drop box gears meshes with is missing some teeth. Do you have to split the tractor and remove the transmission to access this gear? Does anyone have a part number?
Pretty sure the gear you are referencing runs on the main pinion/ring gear shaft. No doubt that would not be a simple shaft to remove. Wish I could be of more help.
