1818 case skid loader
cuby
This has a 2 cyl. Onan engine w/elect. ign. Is there a way to test the module and coil for working order before removeing the engine?? This will not produce spark at the plugs. Have changed plug wire. There is an external cond. that has a broken wire, Does this have a bearing on the no start problem??
Thanks for all the help.
<img src = "https://i.imgur.com/QDWDOgT.jpg">
Condenser is for electronic noise suppression, it should be connected to the side of the coil fed from the ignition switch,.
