Clean and or replace the filter and screen located under the right side of the trans/diff. Check that the pump coupler drive is actually driving the pump. Easy stuff first.
Ben
B
Ditto what centash stated. If hyd oil level at full mark on the stick & is front hyd pump rotating when engine crankshaft rotates? Good hyd diagnostic procedures should be performed before entertaining the thought of front hyd pump problems. Closed center front hyd pump in 1830 requires oil to be supplied to it as it can't suck oil.
What happens if you turn the steering wheel all the way to the end one way or the other? I had a spool go bad in the steering one time and the oil bypassed through it until it was turned all the way.
