184 International Tractor Cub
I have a 184 IH Cub that when the transmission is put in gear the driveshaft will turn, but the tractor will move. If I put the tractor in gear without the tractor running, I can turn the driveshaft and the rear wheels will move. The shaft turns within the clutch housing with no resistance. Would I be correct in thinking the center hub of the clutch disks is broken loose? The trans when engaged seems to be ok.
