We got the new clutch, repaired hydraulic tank repair, etc., finished on my 1958 Ford 1841 Industrial. Cast iron nose is all painted up really nice. Lots of other work to do ahead, but I was so happy about nose appearance I knew I needed a new nose medallion so looked at the recommended reproduction from Dennis Carpenter. I couldn't really afford the $77 shipped price, but gosh, it's Christmas right? I ordered it.
Salesman said I didn't need a new mounting bracket. Medallion arrived. Absolutely drop-dead gorgeous !!! I had been told that Carpenter changed the design to elimenate Ford's mistake of having two Phillips screws mount it from the front because that is where moisture entered and eventually killed the originals. So Carpenter's repro has a solid front and two pegs on the back for mounting. Pegs are steel with no threads. In package are two little spring metal tabs, punched in the center leaving bent inner tips that will, "go on," but resist removel, (they dig into the metal-that's how they hold)
Here, I believe, is a MAJOR problem with Carpenter's design: How does anyone get their hand inside the cast nose to push these #$**@& clips on??????
Removing the center nose cast grill is fine, but the hydraulic reservoir prevents reaching up from the bottom. Headlights must be in place first' can't reach from there. One can, "almost," reach in from the back, across the hydraulic tank, but not enough to deal with the clips.
AND, if I can even install this thing, what if I need to replace a headlight? Ford manual says remove the two Phillips medallion screws, remove medallion and adjust or replace headlight.
I've dealt with these spring clips before. They are often used as cheap attachments for automobile trim, badges, etc. They usually distort when removed if they don't damage the mounting stud of the item trying to be saved.
I emailed Dennis Carpenter. He emailed right back telling me to call them and ask for Jimmy in the tractor department. Jimmy was very nice but admitted he'd never installed one. I asked about threading the studs. He said take it to a machine shop for that. I gently tried a threading die, but the stud material is of an inexpensive quality and merely gauls. I stopped before damaging anything. So Carpenter has no answers.
I hope one of you can tell me I'm missing something. ????????????????????????
From the front, this is a beautiful item.....if it can be used.....
Thanks for reading such a long post.
Dennis Thompson, frustrated...
E WA state
E WA state
