I've had a problem develop recently with my 1850 gas. When trying to start it, it will pop and try to run when you first turn it over, but if it doesn't start then it floods out and won't start, or will start only if I have throttle lever all the way on low idle and it's cranked for a while. It's got a Zenith carb that came from previous owner. Would having the fuel pump in the system aggravate any issues with the float/needle valve not shutting off the gas supply? If it starts it runs well...it's just starting that's the hard part. I've checked the choke and spark and both seem to be open and sparking.
