1850 LP intake manifold
KFFarm
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto4307.jpg
I don't have an abundance of knowledge on Oliver tractors, let alone and LP version. Is this a factory intake manifold, has it been modified, or is it an aftermarket? Please share what knowledge you may have.
second attempt with picture. hopefully it works this time!
I have LP manifold's from my neighbors 1850 that i converted to gasoline, the intake i have don't have the plate welded or attached in the center, other than that looks the same. Steve
I have a pair of LP manifolds from my neighbor's 1850 that I converted to gasoline my intake does not have that plate in the center that's welded or attached other than that they look the same. Steve
The welding job on the manifold is very clean. It s more of a box welded on the bottom of the manifold. I ve not yet removed the carburetor to look inside to see what it looks like. I didn t know if what something from an aftermarket source, or if it was added to strengthen the mounting for the carburetor, or if there was some other reason for it being built like that.
Well Are there any casting numbers on the manifold? There should be 2 six digit numbers on the manifold. One is the Oliver casting number the other one is the Waukesha casting number. I have 2 appointments today. I should be able to check the Oliver number tomorrow.
Here is an additional photo that shows more of a 3D view. There are no part numbers on it that I can see. I'm thinking it has been modified for some reason.
(quoted from post at 20:18:40 02/06/20) Here is an additional photo that shows more of a 3D view. There are no part numbers on it that I can see. I'm thinking it has been modified for some reason.
&lt;img src="https://www.yesterdaystractors.com/cvphotos/cvphoto4410.jpg"&gt;
Looks like it will flow better.
