young tractor
Hi guys. I was trying to shift my 1850 into 1000 rpm and switch shafts. I had 2 problems. I Losened the set screw and got the shifter to move in. I then tried to put a 1000 shaft and bearing that a friend gave me out of his 1750. The shaft slid right in and part way on the bearing and then wouldn’t move. I was afraid to tap it in. I seemed too tight. I had a hard time getting it back out. Did olive make a different sized bearing in a 1750? The other question was then I tried to shift it back to 540 to put the original shaft back in. The shift slide back out, I tightened the set screw but had no working pto. I then tried moving the shifter and now it won’t move in or out. I really worked at and finally gave up. Did something get out of wack? Something move inside that now won’t let me shift ? I don’t understand, the shifter seems like it’s in the right place for 540. I really appreciate your help
