188D sputters
When accelerated it sputters and doesn't seem to get up to RPM. I'm new to tractors and diesels but am fairly mechanically inclined. Seems to be burning a fair amount of oil. I notice that there are tappet that should be adjusted would this help?
Case 188D with a Stanadyne/Roosamaster injection pump? If so, sounds like the plastic governor-retainer ring fell apart inside the pump.
The plastic ring is a common failure item on Case backhoes and crawlers, along with Deere, AC, Oliver, Ford, IH, etc. Basically on all Stanadyne/Roosamaster DB and JDB rotary injection pumps. Used on all Case 188D and 207D engines, like I have in my 580CK hoe and 310G crawler.
When it fails, the engine starts well, runs a bit, then loses power, peters out, and dies. Then, after a few moments will start back up fine- and start the dying process all over again.
