1904 holley carb/truck engine in M tractor
matthies
This tractor was a MD before this install, looks like a clean job, we don't know a lot about it, frame rails don't look cut so maybe from a 460, you might not tell from the pics, but the throttle linkage goes through the block(this might tell somebody what engine this actually is). It showed up tonite at my place and didn't look it over much as I was putting a radiator in a pickup. He didn't have a M fuel tank, but had a H tank.
The throttle control goes threw the block, or behind it.But anyway it does look like M or MD, does it have a serial number plate attached to the clutch housing!!
Throttle goes through the block between 4 and 5, will get you a serial number tonite. Doesn't have a governor, guess it flies just in second gear.
