(quoted from post at 21:11:46 11/25/09) Andrew Z, Since when are the mains shimmed on this engine?? They were, are, and always will be ball bearings.
(quoted from post at 08:27:30 11/26/09) the anouther reason there are inspection holes on the sides, it is to remove the pistons from below without taking off the head. I tried putting them back in that way and i gave up and went from the top down like normal.
Andrew
(quoted from post at 22:59:24 11/28/09) Don't mean to pry in, but heres some pics of the progress I've made on my Regular. When I picked it up the engine was loose, missing the carb, wrong magneto on it and it was flipped around. When I pulled the head I found the sleeves were not in the best shape, they were rather worn out, and the #4 piston was missing the entire skirt on the bottom. So I ended up getting better pistons and sleeves out of a parts tractor I also acquired along with some other parts for it from the same friend.
Anyways here are some pictures of the progress I have made so far
-Jordan
Regular photos
