1935 B gas cap
HectorGP
Thanks for all the good advise everything is running well. Just got one other question Is the fuel tank suppose to build up pressure? When I pull the fuel cap off it pops off into my hand. Most of my old tractors will not do that.
Should not build pressure. Check the vent in your gas cap & make sure the gasket is not blocking the holes either.
yep all the repro gas cap gaskets are WRONG. they are too big in outside diameter & totally block off the breather holes. SOME of the new caps are bad too, not having the vent holes.
