1936 Case CC backlash setting
Swarty1973
I replaced the big clutch shaft bearing on my CC Case. Bearing was still good but I have the engine off anyway so I just replaced it because I was in there. I was told by experienced Case guys that I need to set the backlash and check the gear marking between the clutch shaft gear and the belt pulley shaft gear.
I have the service manual and it says the backlash should be set between.008” and .012”. I have a magnetic base dial indicator on the belt pulley shaft gear but with the engine out, the clutch shaft doesn’t have support on the front to hold it in a neutral position. I need to hold the clutch shaft from moving but each time I get a different reading. The slightest pressure to the side of the shaft changes the reading I get. I didn’t replace the belt pulley shaft bearings, just the clutch shaft bearings.
Once I set the backlash, I then need to check the gear marking (fwd/aft adjustment). But that will be done with gear marking compound - the service manual says to use a special Case tool to set this but it only gives a pet number of the tool, no details of what it is. Any ideas on backlash setting?
What are you using for a service manual? If I remember right there is a solid square steel block
that needs to be fit into place to set the gears. I have the Case service manual, and the steel
block, but I do not have the time right now to figure it all out. Maybe tonight. If someone else
hasn't helped you.
Sorry, .003 to .006 is the backlash range. I have a CC service manual and a Case service tools manual. Both say to use the 02890-AB1 gauge to set the bevel gears but that doesn?t help me since I don?t have the tool and don?t know how to build the tool. I could get one built if I had the dimensions.
No hurry, just trying to do it right
Swarty you need to set the bevel gears with a gauge before you set the backlash.
I don't have them with me, but I have a couple of manuals (for D and DC3) that have drawings and dimensions of the gauges.
I showed the drawings to a machinist, and he handed me a piece of 1/2" keystock (0.002" undersize) and told me to add feeler gauges to get the thickness to match the Case gauge.
I'm wondering why you have so much play in the clutch shaft?
And what condition are the pulley shaft bearings in? This would be a good time to replace them.
They both take a lot of load, and it seems like the right hand pulley shaft bearing is usually wore more than the left side bearing.
The clutch shaft play is what it is I guess. The bearing is new and the play comes from the bearing. Once the engine is back on to support the front of the shaft, it should be good I think. I just don’t see how I can set the backlash with this play in it. If the engine was installed there would be no play in it and I could set it. Maybe I just need to install the engine after setting the clutch shaft gap then set the backlash.
My tool is straight out of the Service Tool Set. The "C" end measures .626". For anyone that is making notes the "L" end measures .8145". The tool is 1/2" wide, but it only needs to be wide enough to fit in flat.
I’ve heard twice that it’s .500” thick and now once that it’s .626” thick. Can I just go to the Walmart and get a 1936 Case service tool kit?
My manual says theres an “L” and a “C” side like you say. So I’m leaning towards your .626”. I guess I can get a block machined thats .500 x .626 and maybe 5” long and see which side looks right in the tractor.
.625 is exactly 5/8”. 5/8 keystock is not common but it is available. And (2) pieces of 5/16 key stock would do it.
