Todd Manteufel
I have recently aquired a 1938 A. It sat for 13 years after my grandfather died. My uncle got it unstuck 2 years ago. I pulled it home 2 miles. I checked the oil and transmission level, emptied the antifreeze that was in it, and filled it with water. I preceded to pull start it. I runs and seems to move ok. I didn"t run it very long. I changed the oil the other day. The filter was partially disingrated, and the filter housing was full of sludge. I Drained, flushed the engine with diesel, new filter, and 11 quarts of 15w40. I am in the process of changing the rear end lube. After I get this done, what should I do next? I also changed the oil in the air cleaner. I am planning to degrease it, rebuild the carb, and drain the gas tank, but I don"t know where to go from there. Money isn"t an issue. Any advice is greatly appreciated. Thanks from an A novice.
