1940 Farmall A part needed
The little L shaped piece that holds the Mag on. It has a screw to hold the top of the Mag tight. TIA
Part number is 46868D.
A 'net search for "IH 46868D" will turn up some sources.
Easy to fabricate, as well.
(quoted from post at 02:12:32 05/19/20) small piece of angle iron and drill a hole make one cut and you have it or send 10 and I will send you an original
I'd just start with a piece a bit long on both ends and spend some quality time with the bench grinder till I got it to where it fit just nice!
