1942 Ford 9N with starting issues
Randy Boltz
I ran my tractor out of fuel...choked it a lot before putting fuel in it...now, won't start unless I pull start it...never had starting issues before. when running, sounds like it is missing. Changed plugs...don't know where to go next...so I came to this forum...any suggestions would be great
I would guess you sucked some crud from th bottom of the fuel tank into the carburator and something in the carb is plugged now. Try draining some fuel out the bottom of the carb and see what comes out of there. That might be all it takes, or you might have to take the carb apart and clean it out.
Try Removing the Plug in the Bottom of Carb 1St.
Like OH Boy said.
Then I would check your Three Filters.
Oh Boy and Getter-Done...The tractor has been sitting since I posted on 12/31. I completely drained the gas tank, took the carb apart, clean all the filters. Turn it over, and started right up...ran smooth all was good. After about 8 minutes, started sputtering again, then quit. Now will not start again. Drained fuel lines, emptied carb from the bottom, checked filters...still nothing. I am going to let sit for a couple days, then try again. Any other suggestions?
