1944 John deere model A
I love this thing like I love any work truck. Gets the job done. Acts like it has a slight miss every so many times it fires on just one of the cylinders. Oils been changed (takes 10 quarts! Wow! Its a 321 ci!), replaced the ail filter oil (engine oil), cleaned the gas float bowl, and adjusted the carburator, just things like that. The flywheel seal leaks, and flings oil, and the clutch seal does a small amount. Its getting worse. Runs great, but there are some things I would like to fix. If possible, I will be taking it to the tractor pulls down the street. How hard is it to fix the flywheel seal? I heard, if the clutch clicks in, then it is in good working order is that true? The Clutch assembley does leak a small amount of oil as well.
Thanks for all and any help!
Trent
Flywheel seal is easy. Remove the flywheel by loosening the clamp bolts and sliding it off the crankshaft. I usually paint mark the end of the crankshaft and the flywheel so you put it back on the right spline. IT IS HEAVY!! Be sure to support it so it doesn't fall. If yours is an electric start you probably will have to make or borrow a flywheel wrench to get at the clamp bolts. You will need to remove the locator pin on the crankshaft. Then remove the spacer cover and slide off the spacer. The cork seal is located inside of it. Then reassemble. Things to remember: You will find Pin sticking out of the back face of the flywheel and a corresponding slot in the spacer. They must line up. If the pin and slot are worn it's a good time to replace the pin and repair the slot. The flywheel must go back on the correct spline to balance the engine. There is one deep spline and a corresponding deep spline in the flywheel. They must line up to correctly balance the engine. When the flywheel is assembled you should have .005-.010" end play on the crankshaft. This is adjusted by sliding the flywheel in or out on the crankshaft before tightening the clamp bolts. It is usually a good idea to replace the clamp bolts & don't use grade 3 bolts, get grade 5 or 8. They have to be tight to hold the flywheel on good. Some leakage around the clutch is common, but very much may indicate worn rings or cylinders causing low compression. Good luck with it.
Paul
