ree515
i just bought a 1945 case tractor that i want to know what i can about it and where i can go for engine spec and history on it. it has a usa amry air borne tag on it and also a us army corps of engineer brass plate on the side of it. it is a J.I Case model s-1 with an se model engine serial # 6600-a any help would be great thanks
SI not S-1 was the industrial version of the S series tractors, S, SC, SO and SI. Many were used during world war 2. Some equipped with a leaf spring supported front axle for air dropping, Were used extensively for base and airstrip preparation in the the Pacific islands.
About 26 horsepower. The number 6600A is the casting number of the engine block and not the serial number. Tractor serial number may be on a plate riveted below the steering column and if plate is missing the serial number will be stamped on the left side of the engine bellhousing flange... Gene
That is a fairly rare tractor you might want to see what color it was painted originally. Could be anything from Flambeau red to Yellow or Navy blue or Olive drab green. see if you can find some of the original color under something like the hood or cowl.
Walt
Here is a Case SI.
<a href="http://photobucket.com" target="_blank">
CaseSIMilitary.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket
</a>
walt thank you. i have identified 3 paint layers the red a olive green and the top is yellow. i have a hydo lift for a bucket on the front the uses a cable on either side of the piston to raise and lower the bucket was that common for these. thanks ree
gene thank you i have found the serial number and you are the first to tell me the horse power i was wondering on that. any thing else you got would be great this is my first tractor if you couldn't tell. i am planing to try to get pics posted in the next few days also. thankyou again ree
Ree;
I have a picture of my "S" in the photo archives listed at the left of this site. Enter Case s in the search and you will be able to locate it. The S and SI are very similar tractors... Gene
If you go to this page you will find some photos of the Case SI Airborne tractors. www.syltech.net If you have the airborne loader which works as you described, it is Hough loader built especially for the SI Airborne. If you have the Case serial numbers and the numbers and information off the military tags I can determine an approximate build date.
he is what i've got off the tag that say air borne
c.ofl.p.o. 231403
date 12 may 1943
us registration# USA 850164
t.m. 5-3012
make j.i. Case
model s-i
here from the amry corps tag
serial# SI 4804886
date mfd 1945
eng 7&8 8-3012
eng make case
mod SE
ser 6600-a
us registration 850164
that is all i got off the tags on the left side is the us air bourne tag and on the right is the corps engineer tag. any thing you can give me will be great thanks.ree
c.ofl.p.o. 231403, Army Corps of Engineers Puchase Order number
date 12 may 1943, Date of contract, 109 tractors were built on this contract.
us registration# USA 850164, This is the Army vehicle number this number is in the 1st 1/3rd of units delivered.
t.m. 5-3012, This the Army Tech manual number
5-3012. This manual is available at portrayalpress.com An excellent manual, worth the money if you are doing a restoration.
serial# SI 4804886, the Case serial number, built in 1944, 1st 6 months of 1944, approximately.
The airborne tag which should be on the right front corner of the front axle support is the tag for the vehicle.
The brass Corps of Engineers tag indicates that the engine was either rebuilt or replaced in 1945. This is a tag that would have be added when a major component was replaced or rebuilt.
There were 1001 of these tractors made for the Corps of Engineers during WW II, so they are fairly rare. I know of about 15 at the present time. Only 2 with Hough loaders.
