I just bought my first M-M Tractor, I have been collecting farm engines for about 30 years. I have always admired MM from the side lines until a late Great Aunt passed away at 100, I then received a box of goodies from a cousin. The box contaied several MM items, come to find out my Great Uncle Wally was a line supervisor at the Lake Street Assembly Plant.
I am in need of a few things for the UTU
a place for good radiator repair, and who carries the full engine gasket set for a KEF engine.
Kirbster
Greetings all! First off I want to thank every one for the great help!
I am making progress on restoring my UTU but I found a oddity that I would like to find out if this is the way MM did it or I may have a cobbled up mess?
On the Pedestal I was removing the hubs to clean and pack them with new grease, I just got tires for the front so I wanted to have them clean when I put my new tires on to move the tractor around.
One hub is different, and does not have a part number on it. The hub cap is smaller and the flange that the lug bolts are on is larger in diameter than the one with the proper part number.
I thought MM put part numbers on everything, because every where you look it says MM made in USA and a Part Number.
Just need some help with this
