prverschneider
Good morning all, new to the forum with a new to me 1946 Farmall A. Has some issues, hoping some of you can point me in the right direction.
Tractor is 6V, positive ground. Electric start, 2 headlights, one rear light. Generator, voltage regulator.
1st issue, very hard starter. Carb is fresh, rebuilt by Carfolo. New plugs, wires, coil, condensor, cap, rotor, points. Everything is clean and tidy. Good spark, timing set with #1 cylinder top dead center. When it does start, runs great, but it does not like to start, cold or hot. Points set at .013, I have heard that with electric start they should be set at .020. No idea if that is true or why it would matter. Air cleaner is cleaned, fresh oil. 100 psi in all 4 cylinders, no stuck valves. Any ideas would be appreciated. Is the timing adjustable? The mag can be rotated a bit clockwise or counterclockwise by the looks of it, maybe it's to advanced or retarded on start up?
2nd issue, wiring on the voltage regulator is not all hooked up. Regulator has 4 tabs, F, BAT, L, and one underneath that is unlabeled. Generator has 2 studs, A and F. Looking at wiring diagrams A stud should go to Gen, which I take to be the tab underneath the regulator. F stud should go to F tab, but only without electric start and lights, otherwise it should be unconnected, is that true. BAT goes to the ammeter, which I have with the 4 position switch. Where does L go? Don't know if the switch works as I'm not there yet. Definitely not charging the battery as I have to keep that on a tender. Not sure how it even charges the battery as one of the wires from the switch goes to the starter, not the battery, others go to the lights. Switch looks like it is wired correctly based on diagrams I have seen.
Any insight would be greatly appreciated,
Pete
Pete
