1948 8N Ford
Kola D
I am looking at a 1948 8N Ford tractor to purchase. Underneath the tractor below the hydraulic pump housing there are (4) 1/2 inch studs sticking down. Two have nuts on them. Can anyone tell me what the studs are for. An attachment possibility? Also the area is wet with oil, which I assume is a leaking gasket. Any help here would be appreciated also. Thanks for helping.
Sounds like the rear swinging hitch studs to me. The 8N had a mounting plate bolted under the rear end with 4-5/8" studs. The plate had a clevis pin in it that connected to a bar that rode on the draw bar. Parts for these are hard to come by. If you need a hitch, there are aftermarket units that use these studs. Available from our host.
Your oil could be coming from a gasket, or perhaps a leak at the rear PTO seal. That is very common. Clean it all up and watch it for a while.
HTH
Kurt-NEPA
