1948 8n value
Doug 13
My 8n has 4 new tires. Also wheel weights on all 4. All parts are put together and tractor reassembled. Has a cracked block. Any idea what it is worth?
Doug 13 , Have a machine shop look at it about putting a repair sleeve in it.Or put sleeve locker on a new sleeve liner and install.I have put new sleeves in a few blocks that have had a cracked bore with no problems.
Don't give it up yet,a repaired sleeve can last for many years with no problems.
This post was edited by Den N Ms on 10/14/2022 at 08:30 pm.
(quoted from post at 22:31:50 10/14/22) My 8n has 4 new tires. Also wheel weights on all 4. All parts are put together and tractor reassembled. Has a cracked block. Any idea what it is worth?
Where is the block cracked and does the tractor run and operate. Bruce is probably pretty close if it runs and high if it does not.
TOH
