1948 Farmall Super A
KacyR
Recently got this tractor running after sitting in a barn for 30+ years. Lately it has become difficult to start and has to be at full throttle, even then starting is a challenge. Once running the engine is making black smoke at idle. Do I have a timing issue?
Black smoke says carb is running way to rich which could be a few things.
#1 choke flap stuck closed so always choked.
#2 air cleaner need to be serviced and have fresh oil put in and also made sure it is not full of dirt dubber or mouse nests etc.
#3 the float could be stuck.
#4 carb main jet could be set way to rich if adjustable.
You could also have fouled plugs or weak spark. Your spark need to be a good blue/white in color and jump a 1/4 inch gap or more at all the plug wires
mite be a good time for some new hotter plugs and have you ran a compression check that would be the first thing to do.
A really really good idea is to take the carb off and soak it in Berryman's or whatever "carb dip" you can find locally. Then poke out all passages with a wire stolen from a wire tag. Blow out with air and place back on the tractor.
There's just 2 circuits, an idle jet and a main jet.
All 4 of my tractors got noticeably better performing both starting and running after I did that (forgotten) maintenance.
Especially after sitting around for a long time.
Good idea. This is a Carter carb and I don't know if either of the jets are adjustable or should be adjusted?
