1948 John Deere A Starter
LWG
Hi Guys,
Thanks for all your help so far! I got the A running, and it sounds pretty good. But when I start it, it takes several (4 or 5) times for the starter to engage. Electrical connections are good, Iv'e looked at the bendix and it looks kinda bad, so I've got a new one on the way. Is there anything I need to know, or will this likely fix the issue? Thanks again!
Is it not spinning or not engaging the flywheel? two different problems two different solutions! Check the ring gear on flywheel too, they get Boogerd up, if it spins but doesn't engage.
It spins every time but the engagement percentage is not good. The ring gear is not great, it is as you say boogered up a bit but not as bad as the Bendix gear.
What mathies sald but be sure it retracts enough the clear the ring teeth. Spring under the pedal makes it retract. Mine made an occastions grinding sound that seemed to come from the left brake. It eventually went away and I never knew what made the noise till I took out the starter and found the pinion was drifting into the ring gear. The ring gear teeth are chipped all the way around but still works.
