1948 John Deere M
Byron James
I have noticed that my tractor has been running a little rough latly. It sounds like it is getting too much gas, or it is an exhaust valve sticking. I have replaced all of these things. I have gotten new points that are set right, condiser, rouder, and a new distributor cap. I also rebuilt the carburator and got new spark plugs and all new wires. If someone can help me out that would be appreciated. Thanks
did you check you carb float level setting? idle and load needle settings? valve clearance setting(.012 cold). just a thought. good luck, d. coleman
The carb float level is set right but I probley need to take a look at the valve clearance, but everything else is right. thanks for you help
might take a look at air filter and ignition timing. the old oilbath air filter screens can get real caked with crud after 60 years. good luck, d. coleman
