Hello,
I have a 1948 Super A that stopped dead on me a couple of weeks ago. After replacing the switch, coil, and condenser I finally found the problem with the points, being that the spring band with the wire attached broke... I replaced the points and gapped them at .020 using No 1 cylinder at it's high point which worked for me years ago. It gets spark now but still won't start and sounds likes it's misfiring. I thought maybe the timing got messed up when I replaced the points as I have limited knowledge on that subject. I didn't mess with the plug wires so I don't think that could be the problem. What should I look for next? I tried a different condenser but that didn't do anything./ I thank you in advance for your suggestions.
