Just finished rebuilding steering box. Replaced all parts that were worn or leaking. Put it together, made the adjustments per the manual. Filled box with 80W oil. Look no leaks. So proud of myself. Turned the steering column on the bench, a light stiff, thought it needed some breaking in. Put the tractor back together and took her for a spin. OH MY GOD. The steering is very hard to turn. Lifted the front end off the ground, steering a little easier. Disconnected the tie rods from dog legs, wheels turn easily no play in frontend. Steering is still stiff with front-end disconnected.
Now, I installed the shims the way they were. Very little up/down play in steering column. Took up the backlash on the sector shafts.
What am I missing? Maybe the sector shafts are too tight? Need to increase end play on the column by adding more shims?
Thanks for comments.
