Jonathan Gurley
Ok guys Here is a good problem for you guys to think about. I just bought a John Deere Model A 49 ... Has electric start.. First off if you pull the throttle all the way down it will cut off because throttle lever isn't adjusted.. When I try to start it like our other A by putting about idle pulling choke and starting it will not start at all. The only way to start it is go full throttle and pull the choke and it will fire up. It runs good once started, but doesn't idle great, Sounds fine at wide open throttle, but when i pull it down to idle(were i think it should) it just sounds different. Anyway just wondering what some possible problems could be, would it be wise to put carb at stock setting on the needles(and i do not know what that is and have no clue which mixture is lowend etc.). If anyone has any specific questions that you need to know to help me solve this problem i would appreciatte it.. thanks.
