1949 w4 carb adjustments???
Matt C.
I recently got my fathers '49 w4 running again after 12 years. It seems to sputter a little bit and then when i increase the throttle, it gets a little worse. I have no manual, so adjusting the carb is puzzling me. If anyone can help me out i would greatly appreciate it. thanks
the upper adjustment screw is for the idle circuit. it is an air controlling adjustment. counterclockwise adds more air. i think the starting point is about 1 and 1/2 turns out. then adjust as necessary. the main jet is a fuel controlled jet. opening the screw counterclockwise add more fuel. start with the setting about 3 and 1/2 turns out. then open throttle wide and adjust as necessary.
thank you so much.......i wasnt sure what the stock settings were, so now i realize i have the air adjustment too far out. i think that might be my main problem. I will start with that and see how it goes. once again, thanks a ton.
The idle adjusting screw is for slow idle (only)
Above idle the vacuum pulling air thru the venture draws fuel from the feed tube, that sets on an angle, and is mixed with that air. Two systems within one. (idle and power) When you are above idle you can take the idle screw out and put it in your pocket and it will make no difference in the high end RPM's. That is why they call it an idle adjustment screw which does adjust the fuel air mixture for the slow idle.
so when I raise the throttle and the engine is kind of sputtering, that is due to the fuel mixture screw am i right? and that is because it is too rich.....or to lean?
For terminology sake I will call the top screw the idle mixture screw and the bottom screw the power jet adjusting needle.
Set the idle screw so the engine will idle at its slowest RPM and still run. You work back and forth with the stop screw on the back to get to this. ( Then forget about the top idle mixture screw)It is set and needs no additional tinkering.
To set the bottom power jet neddle turn it out slowly with the throttle wide open until it will not run any faster and then turn it back in until you hear a slight slow down in the RPM's. You might want to do it over a coupla times. That will be about as close you will be able to get it without a load. If it still sputters you can turn that neddle out some. If it does not clear up you may have some dirt in the power jet blocking the flow thru the jet.
