1950 8n ford 3rd gear tooth missing.
Randy Harris
Should I keep driving and using tractor for light duty or rebuild transmission?
Any thoughts on this.[/img]
This post was edited by Randy Harris on 10/11/2022 at 01:44 pm.
I would drain the oil and look for the missing tooth. I would go
fishing with a magnet. I would fear the chipped tooth could do a
lot of damage.
Or was the tooth ground off?
If ground off look for metal filings.
What would cause it be chipped off or ground off??
I have no clue.
I drove my John Deere B for several years with a broken tooth until on a cold day in January the broken tooth picked up in the stiff trans
lube and got between two gears and bent a shaft in the transmission.
As already posted I would fish the piece out and use it for light duty. Remember that it was designed to be able to spin the tires with some ballast added. As Royse posted a used tranny is readily available no matter where you are. I would not consider rebuilding it.
I would look at the mating gear teeth, and act accordingly. Also find the broken tooth. It looks like the
gear next to it is a bit rough. Is this the countershaft gear? Mark.
(quoted from post at 15:31:54 10/11/22) I would drain the oil and look for the missing tooth. I would go
lot of damage.
I have no clue.
Found the the tooth and cleaned out trans, only makes a clicking sound.
Thank you
Only hear a clicking noise when in any gear while operating at all speeds. Noise never stops, and clicks at trans rpms.
This happened when trans got stuck in 2 gears.
