1950 AR clutch torque
JD29REG
Reinstalling the clutch on a 1950 A, what's the approx. Torque that I should tighten the 5/8 retaining bolt that threads into the shaft?
This bolt
Don't know if there is a torque value or not. I usually tighten it as tight as i can get it and then hit the washer with a brass dolls pin, tighten some more and repeat till it won't go any tighter. Just to
make sure I will hit the end of the socket drive a couple of times with a hammer to make sure it is snugged up. Impact wrench would do the same thing.
first, find out what grade of a bolt it is. grade 8 is around 160 ft lbs, while a grade 5 is about 110 ft lbs. plus use some blue locktite on it. that is a course thread bolt.
Thanks guys, just wanted to make sure I wasn't putting too much on it. I will also use some locktite, thanks for the help.
If you look at the part number of the bolt it is the same for the"A" thru "730 and in the service bulletins the torque is 275
ft. lbs. That torque is to insure that the tapered spline on the crankshaft and clutch driver never move.
No need to locktite it. If you get it as tight as it will go it will not come loose. Idea is to get the driver onto the shaft as far as possible to keep it tight.
Many times the crank and or driver splines are worn and this will allow the driver to go too far on the crank and cause problems with the clutch binding up. With the driver on and tight ideally the end of the crankshaft would be down below the end of the driver 1/4" . If they are flush or even worse the driver goes on past the end of the crank you got problems.
That 200+ torque figure sounds right. We always tightened them "durned tight", but I had the bolt come off once. As it circulated around in there briefly, it created a one-of-a-kind of bulged clutch cover.
When I found out what the torque s/h/b, it was an "Oh S----" moment.
are you sure? a 5/8 bolt will not stand 275 ft. lbs. of torque. that is the torque for a 3/4 " bolt. unless it is a 3/4' bolt in there?? I don't know. just going by what he said and asked for on a 5/8 bolt.
150 ft-lb is more than enough for a plain 5/8 grade 5 bolt in the crank. Crankshaft material is only 1045, a medium strength steel. A broken off bolt or stripped threads is a big challenge. Clutch driver should only be about. 080 beyond crank end, certainly not flush, but more than .120 there's too much pulley travel for proper clutch engagement.
Thanks for all the info. It is a 5/8" bolt on the AR, unfortunately there's no grade marks on it. I'm going to set it to 150ft/lbs (that's the max of my torque wrench) a little lock tite and roll with it and hope I have no issues! "Hope" is key with this project, I received this tractor in pieces and so far managed to get most of it together with only needing a few gaskets/seals and one bearing! This the first project my 14 and 16 year old boys have really got to be part of and get their hands dirty, we're having a good time with it. Hope to get spark to it soon!
