1950 Farmall MD starter question
Hey everyone! Im having some issues with the starter on my 1950 Farmall MD. The starter drive spring got mashed so I bought a new one. It worked great for about a week when it started to have issues again. The spring seemed to get caught again. I researched starters and found where the starter on the MD was the same starter as a crawler starter. So I bought the starter drive for the crawler only to find its rotation is opposite direction from the starter drive that I originally bought.
Which brings me to my question. Can my tractor run with the cam shaft going in the opposite direction? I havent heard of different direction starters. Seems to me that it should run regardless of flywheel direction.
The MD and TD-6 starters must rotate in opposite directions on account of where the starter is mounted.
On the MD it is located in back of the flywheel; the TD-6 it is flipped end for end and positioned in front of the flywheel. Consequently a TD-6 starter must rotate in the opposite direction from an MD starter in order to crank the engine in the right direction.
To your question an your MD run run with the cam/crankshafts turning the opposite direction? In a word, NO.
And even if you could reverse the crank rotation you'd have a tractor with only one forward gear and 5 reverse!
Thanks for your timely reply. I understand why now. I appreciate your knowledge and thanks again. I might need more of your knowledge if I cant figure out why the spring is getting mashed.
I would like to see the "smashed" spring. There could be an issue with a piece of metal in the housing that is getting tossed into the spring as the engine
starts, possibly a clutch component. Looking through the starter hole and turning the ring gear with a small bar (gas Mode) might allow seeing a loose part.
Pulling the belly pump would allow clear view access. Jim
If I see something in there while I put the starter back in Ill let you know, and the original mashed spring looks like it got pinched from the spring over torqueing
