1950 Ford 8n engine rebuild
mikewood869
We're in the middle of rebuild this motor with cast sleeves. Seems like someone was in there before us. Three of sleeve that came out took at least two minutes minimum, cylinder # 3 took 30 seconds. This block is bare as it gets (there's still the oil tub in the block besides the paint on the outside).
Keep sending up dates. I would like to do a engine rebuild next winter so I need to build my confidence until then. The information on this forum is invaluable to a first time 8N owner like me!
The crankshaft is hopefully this week sometime. We still need to clean it and take measurements of everything. I ended up buying a overhaul kit a while ago, but I can t remember for what 8n engine (we have another block that has cast sleeves and a third block that had steel sleeves). Just curious, why would you helicoil the bolt holes for the oil pan? Nothing stripped out yet (knock on wood).
(quoted from post at 00:15:56 12/15/19)Just curious, why would you helicoil the bolt holes for the oil pan? Nothing stripped out yet (knock on wood).
I believe Hobo is talking about the bolt holes in the aluminum cover and basing that on experience. The female threads in the aluminum timing cover are notorious for failure.
Installing steel thread repair inserts in threaded holes in non-ferrous components is a proactive way to strengthen the female threads. Common examples of this practice are the manufacture of new aluminum cylinder heads (spark plug holes) and aircraft components where repeated fastener assembly/disassembly is known to cause failure.
TOH
(quoted from post at 17:11:59 12/15/19)
TOH
Whut TOH said BTDT got the t-shirt...
Anyone know what sleeves would give out the most HP? The old sleeves were cast and we might be getting pistions.
Ended up getting the block back. Now the block will take a Ford model A valve seat. The original camshaft to this block seemed to be out of spec, so we ended up pulling a camshaft out of a different 8n engine (side mount) and got lucky with that. The crankshaft is also within spec too. I ended up with the wrong engine overhaul. This kit has the .40 sleeves and I needed the .90 sleeves (New Holland wants $85 each sleeve, got them for $35 for each sleeve). We might need new crank bearings and the valves might get redo over if I'm missing anything.
Valve seat done
Crankshaft cleaned
Camshaft being cleaned to check spec (looked great after being cleaned
