1950 JD A three point top link,
jrmyers
This tractor is set up with a three point hitch,the top link is a three piece assembly, the sides are threaded stud with a lever on it , 14? inches long into female housing on each end, a three piece assembly, center part attaching to the implement. I am looking for the adjustment stud or parts of this unit. JR
I just found out this is a 801 series three piece top link assembly, each side is adjustable ,I need the stud that you use to adjust one side ,it is 1inch in diameter by19 inches long, 8 inches between threads. These were on A B G 50 60 70 series tractors. THANKS JR.
Below is a link to PC397 the parts catalog for the 800, 800A and 801 3-point hitches. You should be able to find the part numbers you need in it which may help confirm people are all looking at the same part.
PC397
If you don't have a copy of the Operator's Manual, OMA12755, you can download and save a free copy at the link below.
John Deere AG & Turf Bookstore
Click on Equipment publications. Change Model search to Part # / Keywords then type OMA12755 in the search box and search, it should bring the manual up for you. Click on the download icon to the right of the title and it will download a pdf copy to your device which you can save to your device so you can read or print when you wish. If you want to purchase a printed copy or a disc or USB copy, you have to purchase those.
