Boelk
I want to replace the lever shaft seals on the lift unit and valve housing. How do I get the shafts out to replace the seals? Do I have to remove the unit from the tractor?
You have to pull the valve body off to remove the levers, there's grove pins in there that can only be removed from the inside. Isn't that bad of a job, just tedious. A service book helps.
