1950 John Deere A , reduction gear,
jrmyers
My A has a set of gears ,on crank to reduction gear on transmission, filler plug at top of case, drain near bottom,I pulled the bottom plug and a little water, then some off colored oil. came out, teaspoon maybe, I assume they should have a small amount of lubricant in there? Tech manual doesn,t specify. JR.
I think a quart of oil. Ron MN
Have you checked the transmission/final drive?
The manual for my JD 730 says to use the same heavy gear oil as the transmission for the first reduction gear, not engine oil. I would think an A would be the same.
