Hi all, first thanks to everyone that runs and participates on this forum - it has been a great resource over the years! This one has me running out of ideas; though, so I'm hoping someone might have some advice for me.
I'm struggling to get a 1950 Styled 'B' running well again. After the work I've done so far, it starts and idles very well; however, the problem is it doesn't run well anywhere but slow idle. If I open the throttle quickly from slow idle, it puts and sputters and either stalls or barely manages to get up to RPM, where it will run but every few seconds blows pressure out the air intake and almost shuts itself down. It's enough to rattle the oil bowl on the bottom of the air cleaner, and if I remove the bowl it behaves the same way, the air pressure coming out when it backfires (?) is enough to sting you hand if you hold it under the air cleaner, but there doesn't seem to be any sign of ignition (fire, heat, or smoke) coming through that way.
The same thing seems to be happening under any kind of load. The exhaust is clear. Closing the choke slightly seems to mitigate the issue slightly, but the exhaust then has thick black smoke.
So far here is what I've tried:
Ignition: Wico 'X' magneto. Installed a tune-up kit and re-set the points, new plug wires (copper core), new 3116 plugs. We always used Autolite 388s but I learned during this process that non-resistor 3116s are better for the mag. I checked the timing against the flywheel marks and by listening for the impulse while watching for TDC on the piston. I spaced a spark plug out to 3/16" and placed it on the block, confirmed consistent bright blue spark from both cylinders.
Carburetor: DLTX 67. Took it apart and rebuilt it with new parts, bought and used the special drill bits to clean out the passageways. They were fairly gunked up, as was the area around then nozzle.
Verified good fuel supply by opening the petcock on the carb bowl and confirming solid flow of fuel for at least 30 seconds.
Adjustment needles set to 1 1/2 for idle and 3/4 turn for load. Engine will idle with the load needle shut completely. Adjusting these further only seems to make things worse, never better.
Later I tried adjusting the float level in both directions versus the factory spec. of 3/8" from the gasket surface, this seemed to have no effect on the issue.
Fuel: New fuel, ethanol free 90 octane.
Engine Oil and filter have been changed. The crankcase will get gasoline in it if the tractor sits long enough with the carb bowl petcock closed (the valve on the sediment bowl doesn't completely seal). After the carb rebuild I'm hoping this isn't an issue since the needle and seat have been replaced.
After all of the above, it starts and (slow) idles better than it ever has while I've owned it, which is nice, but there's been no or little improvement with the fast idle / under load performance.
So, does anyone have any pointers of what I should look at next, or something I may have missed? What could be causing the backfire (if that's the correct term) through the intake? I'm not sure what to look at next. Any help is greatly appreciated!
