The Dclan Farm
I got the hydraulic remote with closed circuit mounted on the fender. Put the new filter bowl and filter with hydraulic return line on and hooked up. Put the 'tee' on the the pressure line that went to the rear end/transmission housing. lines all connected down to the remotes. All good so far
I started the tractor up. It sounded like it usually does. Not under load. I moved the 3 point up and down to get the air out. Moved very slowly the jerky. Then after a few seconds she came up and as soon as it got to the top and motor went under load. It briefly got better if the moved the 3 point lever up and down, but now always is under load. After 20 seconds of me trying to see what might be the issue I then noticed oil coming out from the filter bowl. I've not yet taken if off
I've got the pressure inline connected to the 'P' side of the remote
I'll message back when i find if i've blown out the filter bowl seal
any ideas?
Here's the serial #4R1C 028077T
any ideas?
