1951 8n Ford tractor
Beard
On the left side of coil 1 is top 2 is bottom. On right side of coil where is 3 and where is 4? Thank you
It seems like you are asking about spark plug wire numbering in the distributor cap of a front-mount distributor, yet by 1951, they had changed to a conventional distributor, a "side mount".
If yours is in fact the OLDER style, here's a visual...
<img src = "http://www.gondtc.com/~blweltin/Bob/Firing%20Order.gif">
I would wager good odds that is not the one marked one, two or three, and will most likely be the one remaining that is not marked otherwise. Bet $.25
