vlackattack
About a year ago I used my B to pull a float in a parade. Towards the end of the parade the clutch started smoking and the tractor stopped moving. I wasn't able to get round to fixing it until a little while ago. Today I unknowingly removed the cover for the oil that's between the steering column and the "dash" with the gauges on it. There was absolutely no oil left in it. I think this may have been the cause of the clutch problem. When I took the cover off, some dirt, leaves, and gasket material fell into where the oil goes. I have a few questions: 1) What should I use to get the leaves, dirt, etc. out of there? I was thinking a shop vac would work. 2) What kind of oil do I put in and how much? 3) How likely is it that the clutch is damaged? Any and all help would be appreciated.
