Hello,
Removed the Mag to double check timing; (plugs have spark, Mag has spark, carb rebuilt, won't start) slot was horizontal with flywheel punch mark at 6 o'clock.
We noticed drive member is cracked on both sides about to fall off.
Only put new points and condenser in MAG XB
Can we swap a Model X spec XH-1042 Mag in its place or should stay with MAG XB spec XB 4001?
Tractor is gas only, 6 volt system, negative ground with a key switch for on/off.
Having trouble with tractor starting now; after running for an hour on first start up.
Thanks, Any advice/help is appreciated
