1951 JOHN DEERE A PTO
pjbofmn
My John Deere A the pro lever moves freely like there's nothing attached. No resistance. If I have to get to the mechanism?
pjbofmn: I bought a 1941 B with the same issue. The PTO lever would move left to right and back with no
resistance. I happened to lift up on the lever and found that you can pull it up but it is spring loaded
back down. While lifting and holding it up I turned it as far as I could and let it go back down again. By
doing that the pin went back into the shifter mechanism and it works again. Give it a try before taking it
all apart. I hope it works for you.
