James Walls
This message is a reply to an archived post by Crem on November 02, 2009 at 19:46:12.
The original subject was "Re: 1951 T020 Rear Differential Question".
Hello to all 1951 owners---I am thinking about buying a TO-20--I am assuming it is with a SN.---TO-39933. Tractor was used last year to bush hog a 10 acre tract or parts of it with no problem.
Tractor needs a paint job and cleaning. I saw maybe one oil leak around the PTO handle--the plate had a little oil around it. Needs a 11x2x28 tire and the other one is great.
I can buy this tractor and bush hog for about $500 bucks. It has no charging system--generator is not wired so I assume it does not work. Basically it needs all oil levels changed / air filter. Guy said it smokes a little not much and was told it is gas smoke and runs rough at times.
I also assume the tractor is a 20 hp---how about being under powered for box blade-- 5 ft.bush hog and garden tiller 4ft.wide.
I have a 18.5 Diesel about 1/2 the size and light in the front end.
Tell me I am not going wrong---Will be used with the implements mentioned above.
Any and all advise accepted----Thanks James
