1952 DC Case Tractor
DennyLynn
I need to find out the exact weight for my 1952 Case tractor. The model is DC. Where do i locate this information or does anyone already know?
(quoted from post at 12:05:41 09/13/10) I need to find out the exact weight for my 1952 Case tractor. The model is DC. Where do i locate this information or does anyone already know?
external_link (I think that's right) will have that info, but be advised they are not always 100% correct.
the only way to get the exact weight is to weigh it yourself. government scale, or grain elevator, feed mill. the book is not exact. for example you may or may not have fluid and how much.
Can you tell us more information?
Such as...
Are the tires loaded?
Does it have the hydraulic pump?
Does it have the eagle hitch?
Does it have wheel weights?
Does it have fenders?
My '49 DC weights just over 5000 lbs with: no operator, no wheel weights, a hydraulic pump, no fenders, and unloaded tires. Factory wheel weights are 300 lbs per pair.
The only way to know for sure is to have the tractor weighed. Good luck.
Like rustred said, if you got an elavotor close by they usually have an outside readout that is always on, just run over the scale and you know what you got. Otherwise there are a lot of variances.
