1952 farmall super M pump
ohiojim
Location
Tn
the hydraulics leak down pretty fast on this old girl,any ideas what the prob. might be? how hard is it to take the pump out ?? do they make an overhaul kit ?? any help appreciated..
If the cylinder it is hooked to is double acting, it might be internal to that. If not there are kits for rebuilding, but they will not repair toast. Good luck, tell us more about the leakdown circumstances. JimN
it's a single acting cylinder,it's an aftermarket three point that worked very well on my H,...it has pretty good lift allthough not as good as the H, but i figure it has lots of leak by to cut down on that...can pump be removed without splitting the tractor ????
Since it is single acting, and it leaks down, The pump and valving in the Liftall should be looked at.
It is removed by removing the Elbow ports, the fill cap, the control rod, and draining the fluid.
Then remove the tin plate to the rear of the pump.
This allows access to the drive shaft and couplings on the trans countershaft. Remove the cotter pins and the shaft will come out.
Now the issue is lowering the pump. It is heavy and awkward. Putting threaded rod into the bolt holes and using nuts on the rod to lower it is easy and safe, and slow. Using a floor jack, and another person is fast and OK if careful. The pump and controls are simple. Look at caseih.com for a parts diagram.
select your country, then select parts and service at the top, choose parts, then choose begin your search HERE. Then put in Farmall. Then M. Then select accessories, then Liftall.
Jim
If you think the leakage is flowing back to the belley pump lift all reservoir, try moving the hose first. Put hose on rear opening left side. Or if thats the one its hooked to try one of the other 2 openings on sides. That moves you to a different check valve to hold pressure on line. If you are using another valve between pump and lift unit disreguard the above.
