1952 golden jub
also looking where I can get brakes replaced, inner and out seals, all springs for a reasonable price in central NY. got a ridiculous quote from one place.
Where is the leak? There are seal rings where manifold meets pump. There are also gaskets within the pump. Does the system seem to work ok? Bleeder plug loose? Where ever it is, yes, there are replacement parts available.
The NAA/Jubilee tractors had external lines underneath.
They are one possible source of an air leak that would make foam.
They are sealed with O-rings. Where is the drip coming from?
Is your hydraulic pump body square or round?
The earlier square pumps may be hard to find parts for.
Rebuild kits are available for the later round cased pumps if needed.
Brake parts are available from our hosts here at YT.
The Golden Jubilee was a 1953 only model introduced in late 1952 so therefore there were 1952 built 1953 Golden Jubilee's. Not real rare but just a few thousand made in 1952.
Yes but they are still called a 1953. Just like right now you can bu ya 2018 car but the title will say it is a 2018 not a 2017. And the same holds true with the jubilee it is still la 1953 tractor
(quoted from post at 01:43:13 07/13/17) also looking where I can get brakes replaced, inner and out seals, all springs for a reasonable price in central NY. got a ridiculous quote from one place.
Off the top of my head
Paying full shop rates if it needs axles and hubs you will need to tote at least $1000 with you to get it out of hock.... To be safe You may even need to bring along a cosigner with you...
