1952 super m farmall
Mark easton
Please help
I have a 1952 farmall super m I can run tractor for 20 min and then it spuders and stalls if I try to restart it right after it does the same thing. But if I wait 5 min then restart get about 2-5 min run time then does it again but if I let it set for 1 hr or more i get 10-20min then starts all over again.don't know if it is fuel or electrical problems. Have checked fuel in carb and line right after it happens
Condenser? Coil? Have you replaced any of these in the recent past? I have seen more than one condenser bad right out of the box.
IMMEDIATELY, when it stalls, remove drain from carb bowl, if it has one, as I don't remember & if no drain plug, then remove the adjustment needle assy & it will act as bowl drain. If flow isn't a decent whizz stream, then start working back upstream to tank, looking for trash in carb inlet/valve, strainer, sediment bowl screen, sediment bowl valve (very small holes catch insect parts & grass & seeds & ?). Sounds like enough may seep thru obstruction to eventually fill bowl then when that cup full is used, it stalls & must sit long enough to fill bowl again with just an old man's dribble for flow.
