1953 ford jubilee
jacktreml
We have a 1953 Ford Jubilee. The 3 pt will not hold up. Tractor has a new pump and piston seals and all the related O-rings. we installed a new hyd. pump relief valve assembly part #NAA638E. We filled the rear end and blew shop air into the port in the transmission case that goes down to the relief. We have air bubbling out. Does anyone know if that is normal or has anyone ever had a crack in the transmission housing
Did you also rebuild the hyd cylinder???
