1953 Super H
John69
I have a Super H that was smoking really bad, so I had the head reworked, and put new rings in it. The tractor starts up and idles good, but when I give it more gas it starts fluttering, and acts like it's going to die. Any ideas on how to fix my problem? Any advice is welcome and apprecated. Thanks in advance.
You need to make sure you don't have a vacuum leak, if it ran ok before installing rings your intake manifold may be leaking. If you have a main jet adjusting screw near the bottom of the carburetor you need to open that at least one full turn. If this doesn't help hold your hand over the throat of the carburetor and see if there's good suction. You will need a helper to do this. Poor suction indicates low intake manifold vacuum.
Did you check the ring gap on the new rings before installing them? If the sleeves were worn
you may need a new sleeve kit. Did you use a glaze breaker on the old sleeves so the new rings have a new surface to seal into? Make sure your valves are set at .020" Cold. If the suction is low do a compression test on all the cylinders and compare the readings. Hal
Did you have someone measure the clyinder bores for wear and out of round, equal tops versus bottoms etc? Have you run a compression test? What was your decision to only replace rings based on? Tom
I checked the suction at the throat of the carb. and it has good suction. I don't have a compression tester. Is there any other way to check the compression without the tester?
It was smoking really bad, is why I put new rings in it. I don't have the tool to check the compression. Do you know of another way to check the compression?
I will try to ask one more time:
1. Did you measure the clyinders for wear? for out of round? top versus bottom?
2. Did you measure ring gap on the new rings?
3. Why did you decide to ONLY replace rings, versus sleeves, inserts, pistons, etc?
Your current problem may be that you need to overhaul the engine. BUT, you need someone to measure everything first to see.
Tom
